Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Triglide tracks to the right
Old Jul 5, 2011 | 02:36 PM
TheBobs's Avatar
TheBobs
Found out what happened. It was caused by a set of Memphis Shields lowers I had mounted on the forks. Took them off since I am switching to a set of modified HD deflectors. It rides straight as an arrow now. Lesson's learned.
Old Jul 5, 2011 | 08:00 PM
oldmsocko's Avatar
oldmsocko
Glad you found your problem.
Old Jul 5, 2011 | 08:16 PM
workhorse's Avatar
workhorse
That's not the solution I was hoping to hear. My "11" tri also very slightly pulls to the right. I have no air deflectors and have added nothing to the forks.
Old Jul 11, 2011 | 10:56 AM
vegas harley's Avatar
vegas harley
Stage III
Default Pulls to right
My new 2011 tri glide pulls to the right and the answer I got from the dealer is that they are made to do that . I think this is BS and need more info to get it corrected.
Old Jul 11, 2011 | 12:47 PM
bronxbill's Avatar
bronxbill
My 2011 does not pull to the right, so they are not made that way. Usual dealer BS.
Old Jul 11, 2011 | 06:07 PM
oldmsocko's Avatar
oldmsocko
I couldn't agree with you more. The dealers must think we are a bunch of retards.
Old Jul 11, 2011 | 07:00 PM
pettifogger1's Avatar
pettifogger1
The problem is that in most cases the trike isn't "pulling" to one side or the other, it is drifting in the direction of road crown. It is very difficult to find a perfectly flat road as they are designed with a crown for water run-off. On mine on some roads it really feels like it is pulling because the crown is so steep. On other highways with minimal crown it will drift, but it is barely noticeable and only takes a touch on the handlebars to keep it going straight. On some roads if you get in the left lane it will drift left.
Old Jul 11, 2011 | 09:09 PM
workhorse's Avatar
workhorse
I have moved to the left lane on a crowned road, and it still will climb to the right. It's not a hard pull, but enough to run off the road in ten seconds at 65mph
Old Jul 11, 2011 | 09:53 PM
TheBobs's Avatar
TheBobs
This is why I posted in the first place. I could ride in the fast lane or the slow lane and it just didn't matter, it would track to the right. Taking off the deflectors fixed that problem.
I have since modified a set of HD deflectors according to Scooty's mod directions. They fit like a glove without any effect on drift.
Old Jul 13, 2011 | 08:27 AM
vegas harley
Stage III
Default Tracks to right
I can come to a stop. Take my hands off the bars and the front wheel will turn to the right. I think it is something in the front forks. I had chrome forks installed on the bike before I ever rode it for the first time. I truly believe it is something in the forks
