Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Triglide tracks to the right
Old Jun 24, 2011 | 06:39 PM
TheBobs's Avatar
TheBobs
Default Triglide tracks to the right
Anybody have any idea what could cause it to track to the right? I only notice it on the highway regardless of lane position. It is very slight and takes only little pressure to keep it straight, but as soon as you let up, it tracks right again. Do you think it could be axle alignment? Would appreciate any advice. It's stumped my dealer so far.
Old Jun 24, 2011 | 07:52 PM
Glyder's Avatar
Glyder
Are you Truly on a level lane??? Most roads are crowned to help with runnoff.
Old Jun 24, 2011 | 08:22 PM
DaveLaBenne's Avatar
DaveLaBenne
That is what I would look at first. A friend had an old tour-glide that needed an alignment at least every other year. His was more of a motor/trans rubber mount alignment. His bike would pull to the right whenever it was out.
Old Jun 24, 2011 | 08:45 PM
dan conner's Avatar
dan conner
it's not like it is a real motorcycle...get a spider...why is this in the new threads? i certainly don't look in the tricycle section.
Old Jun 24, 2011 | 09:01 PM
BinIdaho's Avatar
BinIdaho
Roads crowned here also....if I take hands off handlebars, will wander off to the right. It's the roads, not the trike!!
Old Jun 25, 2011 | 05:59 AM
oldmsocko's Avatar
oldmsocko
You are obviously blind or confused Sir. The post is where it needs to be in the Tri Glide section.
Old Jun 25, 2011 | 07:45 PM
msocko3's Avatar
msocko3
Your dealer shouldn't be stumped because Tech services is always a phone call away. If they don't have a clue they need to get with Tech services for answers.
Old Jun 26, 2011 | 07:53 AM
Buddy WMC's Avatar
Buddy WMC
This is excellent advice. Have the dealer check the fork neck to frame weld for being square. There were some reports that some 2011 models were incorrectly welded in this area at the factory. Therefore, the neck would be out of alignment and cause a pull. I read about one out of Tampa that would do a circle in the parking lot by itself.
This concerned me at the time as mine was a dealer trade out of Tampa. Mine was checked and is fine. I've also noticed what some of the posters have already stated. Nothing dramatic just the way the roads are here.
Old Jun 26, 2011 | 11:31 PM
Dogdaz's Avatar
Dogdaz
Default Tracking
The tracking can be caused by a lot of different things on a trike. Measure up to the rear fenders from the ground on both sides they must be exactly the same, if not this will cause the forks to lean and a pull in one direction or another. Can also be checked by setting the forks straight and using a framing square on the front rotors. This is an adjustment to the rear frame. Also rearend can be out of line at the belt adjustment screws. Break drag on a rear wheel can cause it to pull. The forks could be twisted in the triple tree making it seem to pull to one side. The list goes on, hope this helps, Jerry.
Old Jun 27, 2011 | 09:33 AM
TheBobs's Avatar
TheBobs
Thanks for the responses. I should have mentioned that the dealer did call Tech Services. I originally thought it was the road too, but when it tracks to the right from the fast lane, then I have to assume it isn't the road. Thanks again everybody!
