Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Header pipe wrap?
Old Sep 5, 2011 | 10:26 PM
hdivy's Avatar
hdivy
Default Header pipe wrap?
How much header wrap will I need to wrap a set of stock head pipes on a 2012 tri glide? How far down do u wrap? Will it hurt to wrap all the way to the mufflers?
Thanks
For
Your
Time.
Old Sep 6, 2011 | 01:48 PM
grandpawmoses's Avatar
grandpawmoses
I bought a fifteen foot roll of 2" ThermoTec black on E-bay for $20 delivered & it was enough to wrap both pipes all the way to the O2 sensors (& I overlapped it an inch). I used radiator hose clamps instead of the suggested wire ties. Be sure you're out of the garage & away from the house when you start it up the first time. It's gonna smoke & stink like a burning tire for the first few miles.
David
Old Sep 6, 2011 | 06:59 PM
coupe55's Avatar
coupe55
Default Stinky Cool
David
Yea, I used the sealer also and it smoked and stunk to high heaven for the first 20 minutes or so, sure cool on the old right leg now though! Tried and proven, this is one of the best and cheapest cooling mods we do for rider comfort!
Old Sep 6, 2011 | 07:45 PM
scooty's Avatar
scooty
Default pipe wrap
Can you wrap these pipes withuot removing them ? ? ?
Old Sep 6, 2011 | 09:43 PM
hdivy's Avatar
hdivy
Did u wet the wrap b4 u wrap the pipes? I race karts and we wet it b4 we wrap the pipes on them also did u pull it real tight?
Old Sep 7, 2011 | 05:05 AM
grandpawmoses
Yes, I did & it wasn't to hard.
Old Sep 7, 2011 | 05:06 AM
grandpawmoses
I didn't wet mine but that's not a bad idea. I just pulled it real tight.
Old Sep 8, 2011 | 12:15 PM
bullet 10's Avatar
bullet 10
Had Titanium heat rap with sealer heat paint on mine this summer, pulled rear heat shield off today and rap just crumbled off in floor, also rusting my head pipe front seems okay. Will not replace, seems sentless to me.
Old Sep 8, 2011 | 03:48 PM
coupe55's Avatar
coupe55
Default Wrapping Pipes
Yes, but you can't get the sealer on the back "engine side". I put newspaper behind mine and got them the best I could, sealed most of it!
Old Sep 8, 2011 | 07:39 PM
Diesel-Dawg's Avatar
Diesel-Dawg
Default Pipe wrap
A stupid question but I need to ask. Do you wrap the pipes without taking the chrome pipe guards off and if so, does any of the wrap show up outside of the chrome pipe guards?
