Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Eitms
Old May 12, 2012 | 07:28 PM
Skeet7373's Avatar
Skeet7373
Originally Posted by grayrug
We got stuck at about 10 traffic lights where some lights went thru 2 cycles before we were able to move. I felt the heat on my leg as it was about 78 degrees. At the last two stop lights I noticed the shaking a lot more so than normal and it almost sounded like it wanted to stall out. So is that what I should expect as I got nervous until I started reading this and hopefully that was what it was. Ran good once we were able to get going again.
Mine was acting the same way as yours. I activated it and then the temp went up to mid 80's to 90 degrees. Each time I tried to get thru a bunch of red lights, the trike acted like it wanted to stall. Sounded awful. So I deactivated it. I'll try it again after the 1000 service. Just waiting for the Full Sac mods.
Karen
Old May 13, 2012 | 02:20 AM
msocko3's Avatar
msocko3
It won't stall, it'll just sound like **** and shake your cocktail.
Old May 13, 2012 | 06:34 AM
oldmsocko's Avatar
oldmsocko
Originally Posted by dondee
Yeah, my Dad thinks the same thing.
He was 96 in February...
"GOD" bless him. You are very fortunate to still have him around.
Old May 13, 2012 | 09:47 AM
azbob09's Avatar
azbob09
Originally Posted by oldmsocko
I think shorts are for girls.
I agree, especially on motorcycles! But ,"to each his own".
Old May 13, 2012 | 11:29 AM
joe momma's Avatar
joe momma
I've hesitated asking such a stupid question but what the heck.
How do you know when the EITMS kicks in? Is there a particular noise the engine makes or some other way to know for sure?
The reason I ask is mine has gotten pretty hot several times but I didn't notice anything different behavior going on that got my attention. So either it wasn't activated from the factory or I didn't notice it-which seems unlikely.
I did just activate it per the owner's manual but it's raining here today so can't get out.
...i hope you dont think my question is stupid....i have T/G...what is EITMS ????? ...do i have that ??
Old May 14, 2012 | 05:53 AM
bronxbill's Avatar
bronxbill
joe momma
EITMS stands for Engine Idle Temperature Management System. Basically, what it does is turn off the rear cylinder when stopped under high heat conditions. The idea is that this provides limited cooling of the rear cylinder. If you have a TG you should have EITMS, it is probably turned off from the Dealer. You can turn it on and off yourself by doing the following.
1. Turn ignition to on position
2. Push the throttle to the max roll off position and hold
3. The cruise control indicator will flash either green (on) or red (off)
Old May 14, 2012 | 06:13 AM
dondee's Avatar
dondee
Originally Posted by bronxbill
joe momma
I have to admit I was very surprised to find out mine was disabled from the factory. I would have thought the opposite. It seems like a no-brainer to me. Yes, it's a little annoying but you get used to it and anything to help cool these beasts down a little has to be a good thing, right?
Having said that, based on Mr. Wizard's recommendation I need to get mine in to see why it's coming on so easily-maybe need an update or something.
Old May 14, 2012 | 08:25 AM
Manninagh's Avatar
Manninagh
It says in the manual that it comes from the factory disabled! That said, it took me ages to believe that it was on (despite the green light). It needs basically idle revs and a really high cylinder head temp to kick in. Funny sound as mentioned by others and an odd smell from the exhaust tell you it's working.
On the shorts argument: real men wear kilts
Old May 14, 2012 | 09:32 AM
dondee's Avatar
dondee
I don't know what year your manual is (mine is a 2012), but unless ours are different you might wish to reconsider your little "RTFM" icon. There is not one word on pages 126-127 of mine to indicate whether it is enabled on not from the factory.
And mine is coming on with little to no provocation.
Old May 14, 2012 | 09:36 AM
Manninagh's Avatar
Manninagh
Icon withdrawn, then, with apologies! 2010 here, and of course it's possible that the manual is different for non-US models, but it's very clearly stated in mine - I looked after frying in traffic!
