Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Question about Engine Temps
Old Jun 4, 2013 | 11:15 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Originally Posted by sloufoot
I don't have the PV yet, that is next week...... But the EITMS looks at temps of on at 287* & off at 275*. So I would think anything below 275* head temps are fine..... Just guessing tho.
What are you running on oil temps? But you have that second cooler still don't ya ?
Ride Safe !
Yeah, still running the second oil cooler. Also running the PV now with a basic auto-tune. Also running the Wards Parts Werks CVS fans.
I believe the EITMS pulls the temp off the front cylinder only...wish it were off the rear, but it is what it is.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Jun 17, 2013 | 06:57 PM
TriGeezer's Avatar
TriGeezer
Originally Posted by Moneywoes
Without running my WPW fans I'll see 280's -290's on my 12 TRI. Running the fans I see 250's-260's.
Which ones are the WPW fans?
My tri runs about 270 unless I am riding in heavy rain. Would like to cool it down a tad.
Old Jun 18, 2013 | 12:35 AM
Moneywoes's Avatar
Moneywoes
http://wardspartswerks.com/
Old Jun 18, 2013 | 12:48 AM
DeJavu's Avatar
DeJavu
[QUOTE=Mr. Wizard;11366887]Had a typo in my post Dennis...
Should have read, a sensor for Head Temp doesn't exist.
My 1980 RT had a temp sensor on the rear cyl top fin by the exhaust. Readings vary a lot depending on speed (load) and wind direction. Normal running was around 425 but a good side wind would drop it 30-40 deg.
Old Jun 18, 2013 | 03:23 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
What about all you guys running the TTS tuner? What temps are you seeing?
Old Jun 18, 2013 | 05:26 AM
oldmsocko's Avatar
oldmsocko
I am running the TTS and my oil temps are usually 230 plus I have a 10 row Jagg oil cooler.
Old Jun 18, 2013 | 07:14 AM
Buddy WMC's Avatar
Buddy WMC
+! on what Mike stated. I'm also running Redline 20-60 in my engine due to the high ambient air temps here in SW Florida
Old Jun 23, 2013 | 04:55 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Sorry...I meant to ask of you TTS guys...
What Cylinder head temps are you seeing?
Old Jun 23, 2013 | 09:25 AM
daurwid's Avatar
daurwid
Kevin,
When the '12 tri is warmed up I average around 230 on the fairing oil temp gauge while moving. I have not hooked up my laptop to the super tuner yet to check head temps.
I have the h-d chrome engine fan, stock oil cooler, stage 1 air cleaner, SE mufflers and a super tuner. I am not going to jump into the calibrations until I've removed the cat.
Old Jun 23, 2013 | 09:30 AM
Buddy WMC's Avatar
Buddy WMC
Kevin,
Maybe M3 or the Wiz will chime in. I think M3 has shot some cylinder head temps with an infra red gun and uses the TTS. It maybe me, But I do not think the TTS logs head temps when doing V-Tune runs.
