For those of you that are able to monitor your cylinder head temp while riding... what temps are you seeing on long hot rides?
Related question: What is the ideal/optimum CHT?
I don't have the PV yet, that is next week...... But the EITMS looks at temps of on at 287* & off at 275*. So I would think anything below 275* head temps are fine..... Just guessing tho.
What are you running on oil temps? But you have that second cooler still don't ya ?
Ride Safe !
Hey guys... It's early so forgive my "matter of fact" post here..
I believe you guys are referring to Engine Temp? A sensor for Heat Temp doesn't exist.
There is a difference in Head Temp and Engine Temp when reading data.
Head Temp can reach up into the 400* range. This measurement is calculated by the ECM using various other tid bits of data and is not real. Close, but not real.
Real or not, It is a good base line I feel able to use. With factory tune, temp on the gauge I use would easily be 325 going down road. Now more comfortable and I feel it is nice to be able to check the temp. Dennis
Thanks guys...what I am monitoring is the engine temp on the Power Vision. I believe the PV is pulling from the front cylinder head temp. Please correct if this is wrong.
I am seeing a range of 240-260.
I am hoping these are good numbers. If there is a different range that would be better... ie. what are those who are running a good tune with a TTS seeing?
