Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
starting
Old Apr 4, 2014 | 11:49 PM
sarge205's Avatar
sarge205
Default starting
Wondering wh a tveveryone thinks of the "only starts in neutral" design on the tri glide.
Old Apr 4, 2014 | 11:56 PM
TriGeezer's Avatar
TriGeezer
Is that something new in 2014? It is best to start in neutral, but at least in my 2012 I can start in any gear.
Old Apr 5, 2014 | 06:50 AM
sarge205's Avatar
sarge205
Default starting
Must be a new feature on the 2014, as my new tri glide will only start in neutral. as you can imagine, a brand new machine does not find neutral real easy at first, and I have killed it a few times getting used to the clutch. a real pain in the butt to have to find neutral in a intersection. hope this issue gets better fast.
Old Apr 5, 2014 | 08:06 AM
Moe55's Avatar
Moe55
You can start it in gear but you have to have the clutch pulled in and push down on the rear brake pedal then it will start.
Old Apr 5, 2014 | 08:34 AM
Merri1's Avatar
Merri1
yup, just what Moe said.
I found out about this just by chance. I haven't noticed it in the owner's manual. I too have problems getting in to neutral on the new trike. It doesn't really concern me though. I had a 2012 limited before this and had the same neutral problem until the 1000 mile checkup. I put Synth 3 in all 3 holes and that took care of finding neutral. Also I can find it easier using my heel instead of my toe. Every time I take the trike out I find that I'm likeing it more and more.
Congrats on your new trike.
Old Apr 5, 2014 | 07:05 PM
acunn1's Avatar
acunn1
on my 13 as long as I have the clutch pulled in , it will start
Old Apr 5, 2014 | 11:26 PM
TwinCooled's Avatar
TwinCooled
It's a new safety feature on the 14s. As Moe said simply pull in the clutch and put your foot on the brake and the trike will start in gear.
Old Apr 6, 2014 | 10:27 PM
sarge205's Avatar
sarge205
thank you thank you, and I'm sure the impatient people behind me thank you also!
UHN
Sep 2, 2017 05:57 AM
HDDOC
28
Aug 28, 2017 08:25 PM
Casper
2014-2024 Touring Models
Oct 12, 2015 04:48 PM
HKWildHog
16
Jun 12, 2015 10:38 PM
casper gomez
Sep 3, 2010 01:14 AM
