2016 Start in Gear
Old Oct 9, 2015 | 09:35 PM
Casper's Avatar
Casper
Default 2016 Start in Gear
Ok, did HD change something? My 14 Tri Glide wouldn't start in gear unless I applied either the front or rear brake along with the clutch pulled in.
My new 16 SGS will start in grea with just the clutch pulled in, no break necessary. Are the new bikes all that way? Was this for trikes only?
Just wondering
Old Oct 9, 2015 | 09:40 PM
lp's Avatar
lp
I remember you or someone mentioning this brake thing before.
Must have been a Trike thing or something because it's never been required on two wheel models as far as I know or have experienced.
Old Oct 9, 2015 | 11:16 PM
Brewmany's Avatar
Brewmany
No need for brakes on to start my Limited. Have to either put shifter in neutral, or pull clutch in.
My buddy at work had a tri glide, if I remember I'll ask him about the brake on his trike.
Old Oct 10, 2015 | 12:22 AM
lyork's Avatar
lyork
The brake thing is only on the trikes. Two wheelers just need the clutch pulled in
Old Oct 10, 2015 | 05:48 AM
From_Behind's Avatar
From_Behind
Yep. Just the clutch.
Old Oct 10, 2015 | 12:23 PM
Casper's Avatar
Casper
Sweet, I like it better this way...good to know.
Thanks all
Old Oct 12, 2015 | 11:16 AM
shore's Avatar
shore
I did notice that my '16 starts in gear with the stand down and clutch pulled in. I always thought the stand down was an over ride if in gear despite the clutch pulled in.
Old Oct 12, 2015 | 11:41 AM
From_Behind
Nope, with the stand down, it should start if it's in neutral OR The clutch is pulled.
Old Oct 12, 2015 | 12:05 PM
RollaMo's Avatar
RollaMo
On domestic models, there isn't any kind of switch on the side stand.
Old Oct 12, 2015 | 04:48 PM
Campy Roadie's Avatar
Campy Roadie
To cause you to be stranded when it malfunctions due to placement.
Think of the lack of a side stand inter-lock as a rider competency test
laabdog
16
Jan 24, 2018 02:03 PM
HDDOC
28
Aug 28, 2017 08:25 PM
HKWildHog
16
Jun 12, 2015 10:38 PM
Bob H.
May 13, 2014 05:58 PM
sarge205
Apr 6, 2014 10:27 PM
