Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Lighting Question
Old Sep 7, 2014 | 05:57 AM
Lilman's Avatar
Lilman
Default Lighting Question
Couple of lighting questions for the experts.
Has anyone changed out their front turn / rear stop turns to LED? If so, what did you use?
Personally I think it's crazy every light on this thing is LED other than the stop / turns!
Other question, can the spot lights be adjusted? Haven't played with them but realize the mounting is different for '14.
Thanks!
Lilman
Old Sep 7, 2014 | 07:30 AM
1st 96 ultra's Avatar
1st 96 ultra
changed my rear lights to HD led lights , had them off old bikes and changed the front turn signal to Custom dynamics, dynamic ringz , just plug and play , the turn signal indicators on the dash flashed alittle fast for a few days , the rear lights were normal , then the ecm must have reprogramed or what ever and everthing is normal now , no load eqilizer needed
Old Sep 7, 2014 | 03:49 PM
MB1953's Avatar
MB1953
Unless I misread the manual, loosening the locknut inside the spotlight housing allows them to be adjusted. Had the same issue on my '08 Heritage; it takes a flare nut line wrench to loosen, as the wire for the light is routed through the hollow stem. The manual even calls out a Snap-On part#.
I need to do this as well, since installing the DK Comfort Lift, the lights needed to be re-aimed. Headlight was easy, but the spots take more work.
Old Sep 7, 2014 | 05:53 PM
Jlbflhtc's Avatar
Jlbflhtc
I replaced the stop/tail lights with BAL.
Custom Dynamic LED's were ordered and should arrive shortly for the front turn signals.
No issues with the BAL. I'm told there should be no issues with the CD's either.
Old Sep 8, 2014 | 03:28 AM
Lilman's Avatar
Lilman
Thanks to all! I was thinking Custom Dynamics for the lights but hadn't checked with them yet.
Mark, I would have known that IF I had read the manual...LOL You know me, that's a last resort!
billbrummett
Oct 31, 2018 03:08 PM
balloo
Mar 24, 2014 10:18 AM
Rich B.
15
Feb 6, 2013 04:26 PM
elguapo43
Jun 10, 2012 02:42 PM
Radalack17
Aug 18, 2010 08:09 PM
