Twin Cam Motors Twin Cam 1998 thru 2017
110 to 117 Needs SE Tunner?
Old Sep 4, 2024 | 12:39 PM
doctormota's Avatar
doctormota
2nd Gear
Default 110 to 117 Needs SE Tunner?
Hi Guys!
A friend of mine, is upgrading his 110 fat boy S, with a 117 big bore kit. He has a fuelpak 3, but the bike wont start. Has already asked to V&H and they sent the map for that upgrade, but the dealership is telling him that he has to buy a SE super tunner too, because with the FP it wont work.
Is this true? has anyone had this issue?
Old Sep 7, 2024 | 08:04 AM
Sweep'r's Avatar
Sweep'r
FP3 is not great, but shouldn't keep it from starting...SE tuner is only marginally better due to its having canned maps already for the application
Old Sep 7, 2024 | 01:12 PM
Max Headflow's Avatar
Max Headflow
Compression on the rear cylinder?
Old Sep 9, 2024 | 07:22 PM
juanmanuelrojascavaliere's Avatar
hello
here i have the exact same situation.
i have a 110 fatboy S 2017.
i have a FP3, vance and hines people says that with it , it should start... never did.. but... i had the rear cylinder with 0 compression.
Tomorrow we will have both cylinders ready, Fp3 map inside and will tell you people.
HD argentina says i need the super turner
HD chile says i dont
Regards
Old Sep 12, 2024 | 01:50 AM
Xdash's Avatar
Xdash
New Member
Originally Posted by juanmanuelrojascavaliere
hello
Regards
IIRC. Harley tuners restrict the Air Fuel ratio from going beyond EPA standards. The ratio must be adjusted beyond EPA limits to achieve proper performance.. Tuners are extremely expensive and many will not allow the desired settings..IMO
Old Sep 18, 2024 | 06:27 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Just get a Power Vision.. Problem solved..
Old Sep 26, 2024 | 04:36 AM
8track's Avatar
8track
TTS or Power Vision. I'd check with a good tuner tec in your area
old skool pan man
Oct 10, 2016 07:19 PM
roussfam
Jul 25, 2012 10:12 AM
TheRainMan
Jan 27, 2011 12:38 PM
john lockwood
Dec 14, 2008 02:39 PM
cthecope
Mar 19, 2006 10:05 PM
