Twin Cam Motors Twin Cam 1998 thru 2017
TC88 Cam Chain Tensioner Replacement
Old Jul 21, 2025 | 10:06 PM
Schex's Avatar
Schex
Just checked the HD site, those tensioners are $82 each these days.
I've always replaced the oem's using the Cyco tool and pads, under $30, if you already have the tool, about $30 for the tool, they also have the guide.
https://cycogasket.com/harley-davids...omponents.html
Inspect the oil pump, pieces of broken tensioner pads can run through and scar it, might want to check the crank runout while in there.
Old Jul 22, 2025 | 10:57 AM
Tommy B's Avatar
Tommy B
I thought HD no longer made those tensioners. Glad to hear it if I'm wrong!
Old Jul 22, 2025 | 06:05 PM
Silentgreyfellow's Avatar
Silentgreyfellow
Yup can also confirm they do. I just put a set in a friends bike.
Old May 10, 2026 | 07:27 PM
Tim The Enchanter's Avatar
Tim The Enchanter
Do we need to worry about years of age on these plastic tensioner pads, or just do the 25,000 mile check?
Old Yesterday | 11:21 AM
djl's Avatar
djl
OP, if you followed the video, you did not remove the cams from the cam plate, so you have not changed the timing. Compete the install in reverse; the front sprockets have to line up; no need to worry about TDC, etc. There are a couple of steps in the video that I would not have followed. I would have put the o-ring on the oil pump scavenge spigot; installing it in the scavenge port first can, and has, resulted in a pinched or misplaced o-ring which will result in sumping and require a do-over. Follow the oil pump insall/alignment procedure in the service manual which I did not see the in the video but maybe missed it.
hd4evr2008
Jul 12, 2023 11:36 AM
Sandcrab
Jan 1, 2015 04:52 PM
TexFordD
Exhaust System Topics
Nov 14, 2012 09:00 PM
HARLEYMAN69
Jun 4, 2008 06:57 AM
Professor
May 27, 2007 01:22 PM
