Twin Cam Motors Twin Cam 1998 thru 2017
twin cam trike
Old Nov 5, 2025 | 12:02 PM
bhballs's Avatar
bhballs
Stage IV
Default twin cam trike
I bought a 2005 Electraglide ultra classic with a Lehman trike kit. Looking for some advice. Here are what I know about the motor. 1550 conversion kit w/ high compression pistons, ported heads, SE performance valves, compression reliefs, SE203 cams, SE K&N air filter. Has a SE EFI race tuner kit, not sure of the tune.
I think I need to look at Lifters & push rods. I would like to get some more power out of it; the trike kit is heavy & i am 250. Should I look at a different tune & cams? All input is appreciated.
Thanks, BH
Old Nov 5, 2025 | 12:45 PM
rigidthumper's Avatar
rigidthumper
One way to make it pull like a decent two wheeler is displacement- expensive, but good results. I went from an 88" to a 117, with a bigger stroke flywheel (4.375") from Darkhorse, and a set of cylinders & pistons from Suburban Speed- (low compression 4.125"). Bored the cases, new bearings. Combine with a cam that fits where you need power (I used the TTS150) and big chamber heads (i used 103+ heads) & it turned out decent.
An other option is get a M8 and use the 131 kit
Old Nov 5, 2025 | 02:27 PM
djl's Avatar
djl
Not sure about the M8 option but agree with thumper on the 117; even an upgrade to an all bore 107" would be an improvement. Not matter what the OP does WRT cams, tune, etc. there is no "replacement for displacement".
Old Nov 5, 2025 | 07:35 PM
robarosa's Avatar
robarosa
Should I look at a different tune & cams? newer, more powerful trike? Probably yes.
See what your budget and support.
One hand, Very expensive engine upgrade.
Other hand, Very expensive trike upgrade.
oldman131
Milwaukee Eight (M8)
18
Sep 3, 2024 02:30 PM
Lolojames100
2018+ Softail Models
Jan 10, 2022 01:40 PM
graysbodyshop
Touring Parts
Apr 29, 2015 12:27 PM
babiluth
Jan 10, 2013 08:37 AM
nhebayer
Jan 24, 2012 10:38 AM
