VRSC Models V-Rod, Street Rod, Night Rod and Night Rod Special
What does this plug, plug into? Engine temp not reading. Pic attached.
Old May 10, 2017 | 04:35 PM
Touring_NightRod's Avatar
Touring_NightRod
Default What does this plug, plug into? Engine temp not reading. Pic attached.
I am wrapping up a turbo install and running rich due to not reading temps in Thundermax and fans not turning on. I find this plug, unplugged trace continuity of one of the two wires to the temp sensor for coolant. Looks like the other goes to manifold sensor which also is not reading. Both show minus 40*. I don't remember unplugging anything here, but stranger things have happened. I did remove a powerpro, but that was only connected to injectors.
Old May 10, 2017 | 05:19 PM
Touring_NightRod
After reviewing the schematic and finding continuity between the ECM & the sensor, not sure that it matters. The sensor must be bad, or the unlikely, the Thundermax. I'll get a new one and see if that works.
rwb1
Apr 10, 2014 06:56 PM
Mixter
Jun 15, 2013 07:05 PM
harvema
Jul 2, 2011 11:09 AM
60wt
Nov 12, 2009 07:44 PM
04ctd
Sep 18, 2008 07:44 PM
