Hi.
my friend have vrod 2007 1250cc and when accelerate during touring the engine cut off , to turn engine on he must turn main switch to OFF then ON and push start pushbutton
the dealer checked spark plugs fuel pump connectors for good connection and everything OK there are no error codes and the dealer said that TPS & FUEL PUMP have no error code , is it true?
someone had that problem?
Check your connections. VRod problem#1, bad grounds. Start at the battery, check that one, and on top of the front valve cover ( they most overlooked). Those are the two most notorious. Don't forget to check the positive side as well. But it's generally the ground on the head. Also check the rest of the grounds. Left side on the top of each head behind the horn.
