VRSC Models V-Rod, Street Rod, Night Rod and Night Rod Special
Damn codes
Old Jan 28, 2020 | 06:44 PM
Joseph Bethune's Avatar
Joseph Bethune
Stage II
Default Damn codes
Ok, I have an 05 v rod that I replaced the key ignition. Bike hasn’t ran since. I understand components are married and upon removing one the bikes components need remarried”? I pulled the codes (b 1006 b1007 u1255) off the speedometer in the diag. Also pn 67392 o.i.c Upon realizing this and running around crazy I also see no resp. In the P and S columns. I’m considering pulling every single hair out$&@“ this bike ran great and has been down weeks- I need help or a bigger hammer” somebody help me out here plz?
Old Jan 28, 2020 | 07:05 PM
Rustyg500's Avatar
Rustyg500
B1006 Historic Accessory line over-voltage
B1007 Current Ignition Line over-voltage
U1255 Current missing response from tssm or IM
NoResp - Your on off switch is in the off position. Turn it on before pulling codes.
Sounds like you screwed the wiring somehow. Check your work. You will need a Electrical Diagnostic manual for your year bike to shoot the problem it you can't find your error.
Historic means it happened sometime in the past but is not happening just now.
Current means it is happening right now.
tssm = Turn signal and security module
IM means Instrument module.
Old Jan 28, 2020 | 07:25 PM
Joseph Bethune
Stage II
Very much appreciated” I have no manual so I’m guesstimating. Only way I can get it to start is to wrench jump the terminals on the starter. I know it’s unhealthy but I’m desperate to ride again. The bike will start briefly then done. I’m guessing the security module is shutting off the gas before hitting the throttle body to keep the motor running?? In that case I believe wiring in the start/ run switch is faulty
Old Jan 28, 2020 | 07:50 PM
Rustyg500's Avatar
Rustyg500
What did you do beside replacing the ignition switch? There are only 3 wires attached to it. Possible wires swapped or chafed and shorting somehow.
What happens when you turn the switch to accessory. WOW test should be performed.
Why did you replace the switch? Do you still have the old switch? Re-install it and see what happens. Just changing the switch should not effect the marrying process.
According to my 2003 manual,
Terminal 1 is Red/Grey wire and goes to accessory fuse
Terminal 2 (Center terminal) is Red and goes to Maxi Fuse,Security fuse, Battery Fuse and ECM Fuse
Terminal 3 is Red/Black goes to starter relay, Light Fuse and Ignition Fuse.
Please note I am reading from a 2003 service manual. Things might be a little different on your 2005
Old Jan 29, 2020 | 03:56 AM
BBM's Avatar
BBM
A service and electrical manual are a must IMO, if you are going to wrench.
Old Feb 13, 2020 | 10:59 PM
72 Ironhead XLH's Avatar
72 Ironhead XLH
From an `08
click to enlarge
brave plot
steelerdude1
May 7, 2019 06:19 PM
Camaro67
May 28, 2013 06:44 AM
Hoosier XLC
Mar 27, 2012 07:41 PM
masterblaster
Mar 19, 2011 04:06 PM
trigger1911
Aug 23, 2008 07:58 PM
