VRSC Models V-Rod, Street Rod, Night Rod and Night Rod Special
03 VROD Electrical Issues
Old Jun 26, 2022 | 07:23 AM
Mhcaswell's Avatar
Mhcaswell
Stage II
Default 03 VROD Electrical Issues
I am working on getting my bike started. When I turned the key to ignition the cluster flashed then went dead. When I turned it to accessory the lights came on, but that’s it. Replaced the battery and starter relay. Hooked up the new battery and the marker lights came on with no key in the ignition. Put the key in and turned to ignition and all the lights came on but no cluster and no fuel pump prime. Turned the bike off and removed the key and the marker lights stay on. I removed the security fuse and the lights went out. I even tried disabling the alarm with the FOB but no luck. Any help would be appreciated. Thanks!
Old Apr 23, 2024 | 11:09 AM
sab4's Avatar
sab4
5th Gear
Curious to know if you ever determined what the issue was?
Old Apr 29, 2024 | 04:26 AM
Big Bear's Avatar
Big Bear
When ever I have had odd electrical issues it has come down to corrosion in an electrical connector, particularly the ones under the left side cover on the "tank" on my VRSCF. Unplugging the connectors and giving them a good spray of contact cleaner sorted things out.
Also all the connectors under the seat become quite dirty due to mud etc being sprayed up from the rear tyre. Worth cleaning all these connectors too and maybe adding a mud deflector under the seat.
My Regulator/Rectifier failed, I found that the two connectors on the back, although weather "booted" were badly corroded. The radiator cowl collects mud and water which sit around the connectors. Drilling 2 small draining holes on the underside of the centre cowling has fixed this.
Hope this helps anyone out there. The CAN system can give some odd symptoms if it sees a poor/missing/unexpected connection.
Old Apr 30, 2024 | 06:21 AM
ThunderTruck's Avatar
ThunderTruck
Some great advice, I'll add an issue we chased on another vehicle. Corrosion had traveled up a blade fuse and everything looked fine but it only allowed partial voltage through. Changed the fuse and a problem we spent an hour chasing disappeared.
Jan Tellef
VRSC Models
Apr 17, 2021 02:34 AM
bill1200xl
Jul 19, 2020 06:25 AM
Mrcam216
Oct 24, 2019 02:28 PM
robo74
Nov 25, 2017 10:36 PM
bulldog82098
Feb 13, 2015 10:44 AM
