VRSC Models V-Rod, Street Rod, Night Rod and Night Rod Special
Regulator/Rectifier drainage holes
Old Jan 17, 2023 | 05:33 AM
Big Bear's Avatar
Big Bear
Default Regulator/Rectifier drainage holes
Just in case this helps others. I ride my 2011 VRCSF all year round here in the UK. After some bad weather riding in December had a check engine light come up and found that the battery charging voltage was very low/intermittent.
I checked the alternator output and made regulator/rectifier measurements using info in this forum. The alternator was OK, but the reg/rect wasn't, and both connectors showed heavy corrosion despite their rubber boots. Although I clean the bike quite carefully, it looked like mud/salt/water had accumulated in the bottom of the radiator cowling eventually penetrating the connectors and the reg/rect filling resin. The dirt was worst on the right hand, output side of the reg/rect probably due to parking the bike on the kick-stand, the dirt couldn't drop past the ribs in the cowling.
I drilled 2 x 3/8", 10mm, drainage holes in the bottom of the cowling each side of the centreline just behind the reg/rect location, then fitted the new reg/rect. I can now easily blow/flush dirt out and keep the oil cooler clear too.
Old Jan 17, 2023 | 05:44 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
reelheavy
Jun 24, 2022 06:12 PM
kevjo
Sep 10, 2018 06:51 PM
usmc68
Sep 12, 2017 06:59 PM
pt4u2nv
May 23, 2014 08:50 AM
vacguy
Apr 17, 2010 08:30 PM
