VRSC Models V-Rod, Street Rod, Night Rod and Night Rod Special
Lucas oil stop leak?
Old Oct 3, 2025 | 06:37 AM
Uncletriglide's Avatar
Uncletriglide
It appears from the 1st photo that it's likely to be the transmission drain plug.
It will make troubleshooting easier if you clean the area, then check drain plugs.
If it persists, then check vents, etc.
BTW- In general, stop leak products are bad ju-ju.
Old Oct 6, 2025 | 10:43 PM
poprivit's Avatar
poprivit
Negative on the enfgine goo. If you have to open the enging after using any type of stop leak you will be cleaning for months.
Plus, that crap will plu up everything. Unless you own somethingolder than my 1982 FXRS, stick with factory advice.
Old Nov 19, 2025 | 06:27 PM
Max96's Avatar
Max96
No, do not use that stuff on the bike. If you or one of your buddies have basic wrenching skill just fix the leaks.
Old Nov 19, 2025 | 06:37 PM
Uncletriglide
Agreed. Stop leak type products are generally to be avoided. Bad juju!
jcarruth
Engine Mechanical Topics
Apr 28, 2022 09:31 PM
FatBob-7
2018+ Softail Models
May 30, 2021 09:47 PM
Airshikaritagi
Aug 23, 2012 08:45 AM
powaypete
EVO
13
Sep 19, 2010 09:00 PM
TRRcheck
Mar 29, 2010 10:06 PM
