Just wanted to say "Hi", I'm new to the forum. Just bought a 2006 model Street Rod from Harley dealer in UK. Great bike, I'm 6ft 6 and find it a really comfortable ride. 2K on clock(ex demo). Can someone put me right on a few points?
1/ are the cams ger driven or chain driven
2/ Is engine noise common under 2000 revs until it comes on song(cam)
3/ Are the clutches very "on or Off", and don't like being slipped at all( noisy if done)?
change the oil to synthetic. I had all of the questions you did, until I changed my oil for the first time. I put in Mobil1 V-Twin, and now the clutchis smooth and the engine noise decreased significantly.
ORIGINAL: simon.jmb
Chain driven, as stated. Because of the length needed, they are overhead, and that there are four they have to be. Here is a picture from a cut-away at the manufacturing facility with red arrows pointing to the chain:
ORIGINAL: simon.jmb
The Revolution likes to be at a higher RPM than it's air-cooled brother. I would try not to run it at this low of a RPM. You're not necessarily going to hurt anything but the engine isn't making any power here so there is no need.
ORIGINAL: simon.jmb
The VRSC clutch is hydraulic, it's not going to feel the same as a cable pulled clutch. Hydraulic makes it hard to slip, so yes, they are more "On or Off" than cable clutches.
oooh! Very nice picture Easy! I don't remember seeing this at the KC plant when I was there last. 'Course I haven't been there since Aug '05 and have slept since then
