So, I was reading that the 08 vrscdx shocks are 12.65" long. Is this right? How about the street rod shocks? are they longer? I want to get a little bit more ground clearance. or all vrsc shocks the same length. Using different mounting locations to raise/lower the bikes per the MOCO's specs. I apologise if this has been answered a billion times before
you can have them built to any size.
Available in chrome also http://motorcyclemetal.com/gpage8.html
When Harley got sued for the shocks they switch & had them made. You can still find them used, look on Flee-bay
ohlins just released a line of harley shocks, from good to very good, the base shock uses fully progressive springs and ohlins quality throughout the line, a better bike deserves better shocks
My VRSC, '07 rear shocks are 12.5" C to C. The ride is terrible. I call it the "pogo" stick ride. I don't know thje internal make-up of them but I believe a gas filled and for sure the gas chamber ones would be just fine. The spring rate adjustment is not the issue in my case.
