VRSC Models V-Rod, Street Rod, Night Rod and Night Rod Special
Load Equalizer with run/turn/brake module
Old Apr 14, 2008 | 07:39 PM
rmason's Avatar
rmason
Stage II
Default Load Equalizer with run/turn/brake module
I'm sure this has been addressed, but I couldn't find it.
I have a 2005 VRSCA with security and a run/turn/brake module.
I am changing to LED's for the rear turn signals and I'm having some questions. I purchased a Badlands Load Equalizer III and was reading through the instructions but they do not address if you have a run/turn/brake module. I fired off an e-mail to Badlands but didn't receive a response. So I called them and the person I spoke withsaid that the Load Equalizer III is not compatible with the Harley run/turn/brake module and if I returned the Load Equalizer III with an additional $35 they would send me an Illuminator. When I looked at their tech page, it indicates that if you have a run/turn/brake module you have to use the Load equalizer III due to "melt down" issues. It does not mention any compatibiltiy issues.
Does anybody know whether this a real issue or are they still upset with Harley for "copying their run/turn/brake module" and just trying to make a buck.
Old Apr 15, 2008 | 10:34 PM
rjrivero's Avatar
rjrivero
Default RE: Load Equalizer with run/turn/brake module
I can't help you with the BadLands product. I use a Biketronics Smart Equilizer on my bike with LED's Front and rear. If you are just using LED's in the rear, Some folks have said they dont require an equilizer. The only way to know is to try it and see if you get fast blinking indicating an open ciruit after 4 cycles.
RJ
Old Apr 16, 2008 | 05:45 AM
eazy's Avatar
eazy
My blinkers blinked rapidly after just changing the rear, so I am using the Biketronics as well
RFG7680
Apr 21, 2012 04:21 PM
fenderzig
Touring Parts
Mar 21, 2012 10:27 PM
blz2503
May 20, 2009 07:59 PM
jto667
Feb 15, 2009 10:33 PM
Fisherman 77
Feb 18, 2008 09:46 AM
