VRSC Models V-Rod, Street Rod, Night Rod and Night Rod Special
Power Commander Help
Old Jun 5, 2008 | 09:14 PM
ratdogmiller's Avatar
ratdogmiller
6th Gear
Default Power Commander Help
I just installed my power commander.&nbsp\\; For some reason my fuel level indicator shows my gas tank is empty.&nbsp\\; In addition, when you start your bike the yellow motor light stays on for roughly 4 seconds.&nbsp\\; It then goes off.&nbsp\\; Then it comes back on shortly afterward for another 4 seconds.&nbsp\\; I took out the power commander and the fuel level indicator is working fine, but the yellow motor light is still doing the same thing.&nbsp\\; Do you think the power commander could have screwed up my electrical system????&nbsp\\; I only started my bike with the Power Commander.&nbsp\\; Did not even ride it.&nbsp\\; Has anyone had similar problems.&nbsp\\; By the way it is a 2008 Night Rod Special.
Old Jun 5, 2008 | 09:48 PM
dstlvb's Avatar
dstlvb
Default RE: Power Commander Help
My fuel gauge is worthless, problems started before the powercomannder on my bike.&nbsp\\; As far as the engine light i dont know.&nbsp\\; You might want to do some checking on another V-Rod specific site.&nbsp\\; Probally have some guys there that can help you out.
Old Jun 6, 2008 | 06:56 AM
eazy's Avatar
eazy
The engine light coming on, going out, and then coming back on is because you have a stored trouble code not currently affecting the bike. It's not a problem. You can have a dealer clear it or the next time I'm on from home I can tell you how when I have more time to type if someone else doesn't fill you in first.
Old Jun 6, 2008 | 09:46 PM
ratdogmiller
6th Gear
Thank you.&nbsp\\; I look forward for the information.&nbsp\\; I did speak with the people at Power Commander and they said the same thing you are saying.&nbsp\\; They were saying after 80 starts this goes away.&nbsp\\; The dealer wants to charge me&nbsp\\; $80 to clear the code.&nbsp\\; F@@K that.&nbsp\\; what a rip off.&nbsp\\; I would appreciate if you could help me clear this issue.&nbsp\\; I do appreciate your assistance.
Old Jun 10, 2008 | 01:04 AM
TurboVrod's Avatar
TurboVrod
4th Gear
ORIGINAL: ratdogmiller
I just installed my power commander.&nbsp\\;\\\\\\; For some reason my fuel level indicator shows my gas tank is empty.&nbsp\\;\\\\\\; In addition, when you start your bike the yellow motor light stays on for roughly 4 seconds.&nbsp\\;\\\\\\; It then goes off.&nbsp\\;\\\\\\; Then it comes back on shortly afterward for another 4 seconds.&nbsp\\;\\\\\\; I took out the power commander and the fuel level indicator is working fine, but the yellow motor light is still doing the same thing.&nbsp\\;\\\\\\; Do you think the power commander could have screwed up my electrical system????&nbsp\\;\\\\\\; I only started my bike with the Power Commander.&nbsp\\;\\\\\\; Did not even ride it.&nbsp\\;\\\\\\; Has anyone had similar problems.&nbsp\\;\\\\\\; By the way it is a 2008 Night Rod Special.
&nbsp\\;
Did your odometer or tripmeter blank out also?
fournierrandy
Apr 29, 2015 12:03 AM
Dans03RKC
33
Oct 9, 2014 09:56 AM
goblue90
Aug 31, 2014 04:09 PM
kjay
Dec 3, 2012 11:11 AM
HDJIM1158
Aug 10, 2009 07:02 PM
