My buddy told me is VRod started running on one cyl the other night. Just a dead miss. He checked all the obvious stuff (plug, wire etc)
I think his is the 1st year of em?
Is this common? I've never heard of that happening.
Not common but of course can happen. \\; I would check the coil and the coil connections for that cylinder. \\; May wanna also swap the dead cylinder coil w/ the other cylinder and see if it happens to the other cylinder. \\; Also, check for any codes.
BillyD
Bingo!!!
You were right !! I talked to him tonight. It was a coil. I guess this isn't that common, but according to the dealer
who did the ext/warr repair for him, it's not the first one.
ORIGINAL: Billydj
Not common but of course can happen. \\;\\\\\\; I would check the coil and the coil connections for that cylinder. \\;\\\\\\; May wanna also swap the dead cylinder coil w/ the other cylinder and see if it happens to the other cylinder. \\;\\\\\\; Also, check for any codes.
BillyD
Isn't that sumthin.....
Great to hear the problem is solved.
Does anyone know what year/model V-Rod that had this problem?
Might just want to pass this along to everyone's favorite V-Rod and Street Rod owners...
