That's in the eye of the beholder. The older versions, 2002-2005, had 2 degrees more rake in the front end. When the first 240mm rear tires started coming from the factory, they took 2 degrees out of the trees, which would result in a slightly higher V-Rod. The fork length didn't change. The wheel base would also be just slightly shorter on these newer machines.
