Welcome Area OnlyNew Member Welcome Area Only. Be sure to pop in here and introduce yourself & let us know what Harley Davidson you own. Save your bike related questions for the proper area.
I have a 2004 Road King, while riding the engine shut down and restarted while still in gear a half a dozen times now I've got nothing dash and lights are out. Turn ignition switch to the left and I get dash, front fender lights and odometer reading. I changed ignition switch no change, cleaned battery post's and checked voltage. Battery voltage going to switch and left side less than 1 volt on right side. Any idea What the hell is going on? Russ
You can ask your questions or get advice in the proper sections later.
Welcome to the forums from Ontario, Canada, had a similar problem like that on 2003 RK, I think it was one of 3 relay's, they were all the same part number, that was a few beers ago, I mean years ago, but post in the electrical section, good luck
