ABS sensor install
Had a flat tyre (rear) two weeks ago, so in the dark (enjoying a beer at the time) I took the wheel off for repairs. Due to the time that lapsed, the darkness and maybe the beers, I dont recall which way the ABS sensor came out. The cable that comes from the axle end is molded at an angle and Im not sure if this should face towards the wheel or away from the wheel. Any advice or an image would be greaty appreciated. Bike is a 2014 Wide Glide, So far Ive put 82,000 kilometers on her, reliable as!
I hope you continue to enjoy your ride here to.
Only as a suggestion, by me as a USER, create a signature line similar to my one line on my bike information.
The year, model, and all the letters Harley assigned to the bike. It will appear at the bottom of your post.
Doing this will be helpful if you ask a question. All Harleys aren't the same with many changes and variations over the year.
Of course, you can always add it to any thread with a question.
You can also add any other details you choose and a favorite picture to the signature lines.
If you like, you can also add a favorite picture for an Avatar you see at the top left of all your posts as a postal stamp.
PS .. Questions in the Welcome Area is not the best area for visibility.
Questions would probably get more comments in the proper area using the dropdown menu title FORUMS at the top left on your screen.
Probably here..
https://www.hdforums.com/forum/dyna-glide-models-9/
This is the Welcome area so you may not get the technical responses you are after. Follow Jackie Paper's advice and raise the question in the section he has suggested.
