engine oil
Old Jun 18, 2009 | 06:49 PM
jhugs35's Avatar
jhugs35
Stage I
Default engine oil
hello I have a question maybe someone can answer does a low level in th oil tank keep the engine from turning over
Old Jun 18, 2009 | 07:17 PM
oct1949's Avatar
oct1949
It won't and don't.. Now, no oil in the tank and a froze up motor will not turn over.
Old Jun 18, 2009 | 11:33 PM
Ultra 08's Avatar
Ultra 08
Welcome from Virginia
Not unless you ran it so low it locked up,
Old Jun 18, 2009 | 11:35 PM
ptw***'s Avatar
ptw***
Welcome from Sweden
Old Jun 19, 2009 | 12:34 AM
cajunrph's Avatar
cajunrph
Welcome from the Texas gulf coast area. So low it seizes the engine, but not just being low. You might want to post this in a tech forum here. Most here will just welcome you to the group.
Old Jun 19, 2009 | 05:41 AM
hpfatboy's Avatar
hpfatboy
Thumbs up
Welcome from Surrey B.C. CANADA
Old Jun 19, 2009 | 06:06 AM
Geezer2's Avatar
Geezer2
Welcome from central Washington. Great site and even better people. Use the search function and snoop around a bit before asking questions . Just a little brotherly advice. Glad you're here . Geezer
Old Jun 19, 2009 | 07:24 AM
Wassup8687's Avatar
Wassup8687
Welcome aboard from New York.
Old Jun 19, 2009 | 07:25 AM
tjvrodrick's Avatar
tjvrodrick
Welcom nice to have ya.
Ride Safe and have fun here & on the road
If the check valve in the pump is bad it will let the oil fill up the lower end an the engine will not turn over is the oil in the tank low ? if yes remove the check valve spring and ball clean and replase drain the oil from lower end refill the tank had to do it on you 1992 flhtc not hard to do.
Rick From San Diego / TJ Mexico
1992 flhtc
2002 V-Rod
soon to join the 260 club
AW wheels
Metzelers
V-mods
Old Jun 19, 2009 | 07:57 AM
P'colaHarley-17RGS's Avatar
P'colaHarley-17RGS
welcome to the forum.
