Dumb Softail question...
Old Aug 8, 2010 | 11:36 PM
lucky jim's Avatar
lucky jim
Default Dumb Softail question...
Hey all,
I went to go look at a used Softail Custom with really low mileage today, and when the guy started it up I noticed the headlight was bouncing around, and then even saw the front wheel shaking back and forth a little bit... the front end was shaking a lot more than I thought it would.
is that right? I mean.. I know it's a big motor, but Softails are supposed to be balanced. I thought it was the Dynas that shake at idle. And if a Softail's like that, I can't imagine what a Dyna is like
I'm just checking to make sure this isn't some problem with the bike...
Old Aug 8, 2010 | 11:40 PM
chasmo46's Avatar
chasmo46
Harleys shake... AND I like it.
Thats why they call them "Rollin' Thunder."
Old Aug 9, 2010 | 07:20 AM
Wassup8687's Avatar
Wassup8687
Welcome aboard from New York.
Old Aug 9, 2010 | 07:48 AM
sh57's Avatar
sh57
welcome from north carolina, you did not mention what year model you were looking at, some shake more than others.
Old Aug 9, 2010 | 08:36 AM
prostar's Avatar
prostar
It is normal, I hope it helps me be seen by the annoying boucing. I'm talking about the light, the front wheel shaking doesn't sound right.
Old Aug 9, 2010 | 08:55 AM
Dog Father's Avatar
Dog Father
I guess it depends on how much it was shaking. Did you ride it? If you rode it, you would be able to tell if it was normal or not (feel looseness in the wheel, etc.) My 03 Heritage doesn't shake very much.
Old Aug 9, 2010 | 09:28 AM
cromagnon's Avatar
cromagnon
Touring series rubber mounted bikes shake a lot when they are ideling and get real smooth the faster you go.
Softtails and Dynas are counterbalanced. The are supposed to be smooth at idle, the the vibrations pick up a bit at high speed.
Old Aug 9, 2010 | 10:12 AM
DGDeuce's Avatar
DGDeuce
Welcome from NY. My Deuce doesn't shake much at all. Bring someone with you that knows more.
Old Aug 9, 2010 | 10:34 AM
Double_Trouble's Avatar
Double_Trouble
Originally Posted by prostar
It is normal, I hope it helps me be seen by the annoying boucing. I'm taliking about the light, the front wheel shaking doesn't sound right.
+1 on the light bouncing (like a strobe light).
I put my toolbag on top of the light and that cuts out most of the bouncing.
My wheel does not bounce or shake in any way.
Old Aug 9, 2010 | 10:51 AM
ky1bnusmc's Avatar
ky1bnusmc
Welcome and Hello from Eastern Kentucky.
