Welcome Area OnlyNew Member Welcome Area Only. Be sure to pop in here and introduce yourself & let us know what Harley Davidson you own. Save your bike related questions for the proper area.
I do not know if you can remove the baffles on the stock pipes........if so there will be a screw at the rear bottom side of each pipe, take it out.
Looking into the pipe you'll see the baffle and it is a tight fit but with screw drivers, needle nose pliers and alot of pulling you should get it, maybe use alittle WD_40
Welcome aboard from Kitchener, Ontario Canada! As for your question on baffles.....you will get quite a bunch of differing opinions here. But, you should try a search or post in the Tech Forums to reach the right target audience. Ride safe!
