speedo problems
Old Jun 22, 2011 | 07:49 PM
shawn175's Avatar
shawn175
Stage III
Default speedo problems
hi all i`m having problems with my speedo on my dyna super glide. the needle stays at 160 km. when i drive the needle works but starts reading from 160.i changed sensor but still staying on 160.i didn`t try it for a drive yet i just started it up to see if it would work.if anyone has suggestons for me please let me know thanks.
Old Jun 22, 2011 | 08:23 PM
Wassup8687's Avatar
Wassup8687
Welcome aboard from New York.
I would recommend posting in the funds area.
Old Jun 22, 2011 | 09:09 PM
KSRoadKing's Avatar
KSRoadKing
Welcome to the forum from Kansas
Old Jun 23, 2011 | 11:00 AM
Jackie Paper's Avatar
Jackie Paper
Welcome from Virginia...USA. Called a WOW test. Ignition off, hold miles reset in and turn ignition on, release button, needle should peg and reset itself. All lights should check. If not check plug on back of speedometer (unplug,replug it in). Recheck. If fails make sure wires from speedometer plug look good going to the other components. Especial the ground wire. Your display will read different codes which you can hit the reset to go thru. Holding the reset 5 seconds in any section will clear the codes for that section. You really need service manual to do the full self diagnostics. There is 8 pages for my Softail in my Electrical Diagnostic Manual. (not the owner or service manual) PM me what you find out and I will try to walk you thru it if you are not rushed for time.
Old Jun 23, 2011 | 06:53 PM
shawn175's Avatar
shawn175
Stage III
thanks for the info gr000 i will try what you said
Old Jun 23, 2011 | 09:28 PM
2012UltraLimited's Avatar
2012UltraLimited
Welcome from Vancouver, Canada
Old Jun 24, 2011 | 06:20 PM
racerdj's Avatar
racerdj
Welcome to the Forum from Indy!
Old Jun 30, 2011 | 08:30 PM
Gator454's Avatar
Gator454
Welcome to the forum from southeastern Michigan!
Old Jun 30, 2011 | 08:33 PM
82ndABN's Avatar
82ndABN
Welcome from California..........
Erbie
Feb 18, 2017 10:12 PM
jessekr
Electrical/Lighting/Alarm
Oct 27, 2014 10:19 PM
Dzl08
Jun 3, 2014 07:05 PM
53driver
Jun 30, 2011 10:50 AM
2001 softail
Apr 27, 2007 09:28 PM
