Welcome Area OnlyNew Member Welcome Area Only. Be sure to pop in here and introduce yourself & let us know what Harley Davidson you own. Save your bike related questions for the proper area.
Hello guys!! Needing some advice on Rake, fork length and wheel size.
I`ve seen a nice custom bike i like the look of, its got stock length down tubes, 38deg rake, its front end is a stock length springer,with a 21" wheel.
Im looking at starting my own project in my Garage{2 kids under 3 and a full time wife living with me} so im prepared to spend a few years in there!!.
im liking the look of the 38 deg rake,but id like to use a 2under springer with a 23" front wheel {18"rear},does anyone see any problems with this?? is rake to much at 38?? will there be any ground clearance issues, frame sitting front end low/high etc?? any info would be great,pictures of project with similar sizes would be awsome,
Thanks for your time,
Wish I could help you, but I haven't done a ground up since the 70's. I had a 40 rake with a five foot springer hardtail. Now it comes down to frame before rake. The only problem with the rake is comfort and maneuvering. What are you starting with?You can't really do a ground up without a builders license anymore. A little more information will help others with your build. It sounds like you were about my age when I did my first build, so maybe comfort isn't a problem for you.
