Crankcase Issue?
Old Jan 24, 2013 | 12:26 PM
TDH1904's Avatar
TDH1904
1st Gear
Default Crankcase Issue?
So this is where I am at with the tear down.
I was thinking I just needed new rings and a carbon clean on the pistions and valves, maybe a valve job too. Then I pulled the lifters...
I found pitting on one of the lifters and the lobe of the cam
So I pulled the cam plate and Found this... Something had gouged out the the bore of the lifter.
After further inspection I saw that the lifter(crane cams lifter) flange on the pin for the roller at the bottom failed and damaged the wall inside the crankcase on the inner cylinder (right side).
Now the cams are (Andrews cams) not sure if that makes a difference that the lifter and cams are from different companies, or if that matters at all.
Now I am at the point where, can this be welded and rehoned or do I need to replace the right side of the crankcase altogether? Another idea that was offered by a salty sea dog was to clean out the burs and run as is because the tension was mainly front to back and not side to side.
I started at 100$ then kept going and finding other problems then it went to 1300$ with a big bore kit http://www.fuelmotousa.com/site/107-inch-big-bore.html that would replace all parts and give me more power, now I feel it will be $$$ to fix this crankcase issue...
Thanks HDF!
Attached Thumbnails Crankcase Issue?-photo-1-.jpg   Crankcase Issue?-photo-2-.jpg   Crankcase Issue?-photo.jpg   Crankcase Issue?-photo-6-.jpg   Crankcase Issue?-photo-7-.jpg
Old Jan 24, 2013 | 12:29 PM
TDH1904's Avatar
TDH1904
1st Gear
I am not seeing my photos posted so If you would like to see more send me a msg and I can email you the pictures for further help!
Thanks.
Old Jan 24, 2013 | 12:47 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Old Jan 24, 2013 | 02:50 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
Welcome to the HD Forums from Texas. Nice to get an update on your tear down.
Old Jan 24, 2013 | 04:09 PM
the wild hog's Avatar
the wild hog
Welcome from the Sunshine State.
Old Jan 24, 2013 | 09:05 PM
2011Deluxe's Avatar
2011Deluxe
Welcome!
Old Jan 24, 2013 | 09:21 PM
jmale1972's Avatar
jmale1972
Good luck with your project and welcome to the forum from Nashville!
Old Jan 25, 2013 | 10:31 AM
ceebaileys's Avatar
ceebaileys
Former Sponsor
Welcome from SoCal
Old Jan 26, 2013 | 01:48 AM
TDH1904's Avatar
TDH1904
1st Gear
A lot of welcomes here but not so much in the area of help. I thought this site would have some words of wisdom when it came to my dilemma.
Thanks anyways...
Old Jan 26, 2013 | 08:11 AM
asm481's Avatar
asm481
Thanks anyways...
Welcome to the forum. I think everyone is, (without saying it), wishing you would post your problem and pictures in a different thread in the right discussion forum such as engine related. This forum is for greetings and that is what you are getting.
PS I am interested in what others say about your crankcase problem.
And....Welcome to HDForums
