wide swingarm on Deuce
Old Sep 2, 2015 | 04:37 PM
philmc's Avatar
philmc
Default wide swingarm on Deuce
I put a wide swing arm on my 2000 Deuce. I put the Zodiac swing arm that they said would accommodate a 240 or as large as a 250 tire. My question is are there any persons out there that has done the same. I would like info on the size wheel. Will the Harley "Breakout" wheel fit my bike. This axle that came with my swing arm is the same size as the stock axle that I had on the bike. If the breakout wheel will fit my deuce, will the sprocket on my stock wheel fit the breakout wheel. Any help would be appreciated.
Thanks
phil
Old Sep 8, 2015 | 04:03 AM
grbrown's Avatar
grbrown
Hi Phil, I suspect your project is pretty rare in here and you may get a better response over in the Softail forum.
jd8181
May 15, 2021 08:38 PM
grbrown
Dec 29, 2017 05:19 AM
thephantomsfire
Jun 13, 2012 01:40 PM
retarmycol
Jul 26, 2010 02:39 AM
rolfsharley
Wheels/Tires
Feb 9, 2010 03:48 PM
