I'm pretty sure that a 21" wheel will fit just fine if it has the right tire on it. I think the 100/90 has a total diameter that is fine for where a stock fender is.
A 21 x 3.5" with bolt right up with your stock fender with no problems! But like with cars no two Harleys are exactly the same, the specs may be slightly different, occasionally you may need to loosen the back two fender bolts and angle the fender down to get more clearance. You may even need to take the rear bolts out a drill a slightly bigger hole so you can move the fender a bit further.
But a 21" Rim WILL fit with your 2012 Road King Classic!
On a Road King you would probably want a 21x3.5" rim with a 120/70/21 tire in order to fill up the fender nicely. Sure you can use a narrow 21" wheel if you want but if you are going to buy a wheel you might as well get a wide wheel as it looks better and will ride better on a large touring motorcycle.
installed a 21x3.5. getting a horn/harmonic noise when i use front brake. made spacers to fit new wheel. new rotor and pads as well...no luck. any help wpuld be awesome and good luck to you guys!
