21 x 2.15 and 21 x 3.5
Old Dec 7, 2015 | 11:05 PM
Tonebone357's Avatar
Tonebone357
Stage I
Default 21 x 2.15 and 21 x 3.5
Hello there!!!!! I have a 2000 duece that has a 21 x 2.15 80/90-21 front end wheel and i was wondering if i could use a 21 x 3.5 without changing anything, if i can do so plz help me...
Needs to get my 2 wheel therapy in
Old Dec 8, 2015 | 12:27 PM
grbrown's Avatar
grbrown
Hi from the UK and welcome to HDF. Your current 2.15" rim width is suitable IIRC for an 80 or 90 wide tyre. A 3.5" wide rim is only suitable for a 120/70 or similar size low-profile tyre. If that is what you want to move over to all you need is a wheel builder to supply and rebuild your current hub with that size of rim. Alternatively you can buy a ready-made custom wheel of that size. We have HDF sponsors who will be pleased to do that!
Old Dec 10, 2015 | 03:04 PM
Hogpro's Avatar
Hogpro
Former Sponsor
You will need a different front fender to put the wider rim/tire combo. Unfortunately for the Deuce it is yet again the case of fits all softails but the deuce for front fenders.
Old Dec 17, 2015 | 04:03 AM
LoneWoolf's Avatar
LoneWoolf
Hogpro, just so I 100% understand. On my 2001 Deuce, if I wanted to go from the stock HD 21x2.15 wheel to a 21x3.5 I would have to either run without a front fender or have a custom fender fabricated? Otherwise, it would be a simple switch to a new wheel. The complication is in the fender fitment?
Old Dec 17, 2015 | 08:18 AM
Hogpro's Avatar
Hogpro
Former Sponsor
Stock fender will not work. There are no direct bolt on's that I know of for a deuce.
Old Dec 17, 2015 | 05:30 PM
LoneWoolf's Avatar
LoneWoolf
Thanks,
Old Dec 22, 2015 | 01:02 AM
AKFXD's Avatar
AKFXD
Maybe you could get a set of fork sliders for a standard soft tail and swap them over so you could put on a fender that fit.
oldemastiff
Aug 12, 2013 06:01 PM
Iron lHorse
May 4, 2011 09:21 PM
acswg
Feb 26, 2011 11:09 PM
getinked
Wheels/Tires
Apr 2, 2010 01:07 PM
KG
Apr 3, 2005 12:59 AM
