200 rear tire
Old May 21, 2016 | 10:04 PM
SE120RG's Avatar
SE120RG
Default 200 rear tire
I have a PM 21/17 wheel set on my SG. Wondering if anyone has used the stock Dunlop (200/55/17)off a fatboy on a newer touring or will it rub on the belt
Old May 25, 2016 | 09:19 AM
WanaRyd Wheels's Avatar
WanaRyd Wheels
Sponsor
All we've come across with the 200mm tire is that it make hit the rear fender bracket on the 14-16 Touring Models. All you'd then need to do is pop it off and bend the fender bracket outward and put it back on. I can send you instructions on that if you do come across that issue.
__________________
WanaRyd Motorcycle
1-888-926-2793
Old May 25, 2016 | 08:13 PM
SE120RG's Avatar
SE120RG
thanks for the info. Have you ran the dunlop combination front and rear? or will that cause an error with the abs/linked brake system?
j09789
Apr 27, 2023 12:35 PM
Madd Max
May 15, 2017 07:20 AM
GibsonSG
2014-2024 Touring Models
Nov 15, 2016 01:48 PM
Android
May 14, 2013 08:47 PM
va_rider
Sep 13, 2010 09:50 AM
