RK wheels fit a softail?
Old Jul 22, 2016 | 01:55 AM
ARBOC's Avatar
ARBOC
Default RK wheels fit a softail?
Will 2005 Road king spoke wheels fit my 2003 heritage softail?
Someone put mags on it and I want spokes back.
Old Jul 22, 2016 | 08:41 AM
multihdrdr's Avatar
multihdrdr
Touring Fronts (Road King) have a different LEFT bearing to rotor mounting surface dimension. You need to stick with Softail unless you want to do some machining.
About the Rear...In 2003 Softails changed the Rim to Hub offset when they introduced the 150 tire. The Touring rear will go on easy enough, but your tire to belt clearance will be reduced (maybe the tire will will touch belt...Dunno for sure). Since you want to use Laced Spokes, you can always have the offset adjusted, but that's an additional cost.
Kennypatterson
Sep 2, 2015 05:36 AM
speedy540
Aug 11, 2014 06:26 PM
Road Star
Nov 27, 2013 03:51 AM
MSG Hall
Oct 8, 2012 12:08 PM
joshh
Oct 4, 2010 09:14 AM
