The tire has rubbed through the right turn signal wires twice.
What was the years of the sporty rims that will fit the 01 dyna again please sir
It's a shame to I like that rear rim..
Quite a few HD Model wheels will fit your 01 FXD. Some directly, some with a bearing change. As far as using a Sportster Rear, 2000-04 Direct fit, 05-07 with a bearing change
There are ways to move that wheel over slightly if you want. Basically, you put a small spacer between the caliper bracket and swingarm. Whatever spacer size is used, you would then remove that amount of material from the LEFT spacer (then the total width remains the same).
Can you take a good shot of the centering of the rotor within the caliper. You may have to take a couple slightly off center (right and left of rotor)... Cameras don't work like our eyes
Being from a "Fatboy" in itself is not an issue. 2000-02 Fatboy Rears are really the same as all others in the critical dimensions including offset (Sportster, Dyna, Touring...the same). In 2003, softail 16x3 Rears changed their offset. That's why I wondered if it was from a 2003-06 Fatboy.
