speedo conversion.
Old Jun 13, 2017 | 11:04 PM
sporty65's Avatar
sporty65
Stage II
Default speedo conversion.
Hey everyone.
I have a 1990 sportster 883. I,m installing a set of fatboy centerline wheels on it. Going from 19" front wheel to 16". Tring to figure out best way to convert speedo so it will read correctly. Any ideas. I have a fatbob dash on it with 5" speedo. was thinking about trying speedo drive and speedo from fatboy. but i dont know?
Old Jun 14, 2017 | 01:39 AM
Yamaharley's Avatar
Yamaharley
First I would find the height of a 16 inch wheel with tire vs a 19 inch with tire. Also there might be a different speedometer ratio used in each one, like 2:1 for example.
Old Jun 14, 2017 | 04:18 PM
sporty65's Avatar
sporty65
Stage II
yes the ratio for the sporty is 2:1 and the fatboy is 2240:60. just need to see if speedo drive from fatboy will fit on sporty. if so it should work. Theyre both 3/4 axles. prob just need some different spacers. gonna check with local dealerships parts guy. hes pretty good with swapping parts from model to model from what ive been told.
Old Jun 16, 2017 | 10:57 PM
Yamaharley's Avatar
Yamaharley
I would check the spacers and the speedometer drive to see if you can fit them. The one other thing is on a big twin there is a hole in the backbone to feed the speedometer through. You can probably just run it to the side of the sportster backbone.
eagle56
Nov 17, 2010 03:29 PM
painey
Nov 30, 2009 05:31 PM
vord
Jun 26, 2007 07:59 AM
batch
Feb 13, 2007 08:47 PM
MickW
Jul 3, 2006 01:05 PM
