Wheel Balancing
Old Mar 29, 2018 | 03:14 PM
kel03's Avatar
kel03
Default Wheel Balancing
I brought in my 28 spoke knuckle rims to get my new Dunlop American Elites installed. Got the call, ready for pick up. To my surprise, I looked for the weights because I was specific on where to place them. They needed no weights. I asked the guy, who owns the shop, because never had this happen before. So, the question, anyone else run into this? Thanks for replies.
Old Mar 29, 2018 | 03:25 PM
2500hdon37s's Avatar
2500hdon37s
Sometimes it works out that you dont need them. although rare.
Sign of a quality tire if it needs none or near zero weight added to balance IMO. Usually with spoked wheels you need something though. After running Pirelli Night dragons on my bike and installing them myself, I dont even bother to balance them, throw in an ounce in the front and 1.5-2oz of balance beads and run it. That way as they wear its always perfect in balance.
Old Mar 29, 2018 | 03:35 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
OEM cast wheels and quality tires need little balancing if any. Why so many people think beads rolling around in there is doing something. No weight on my front. Maybe a couple 1/4oz on back. Doubt you could tell it if I took the two 1/4 oz off the back.
They do need to be dynamic checked. Spin balance on modern quality equipment that shows out of balance in two planes. Especially the wider rims on modern bikes.
Old Mar 29, 2018 | 03:50 PM
sbrmike's Avatar
sbrmike
I never had my wheels/tires balanced on my Shovels and Sportster when I had them; the yellow dot by the valve stem and good to go.
My Softail has the factory cast rim 17 x 6.00 with a Dunlop 402 220-55-17 on it and it has nine or ten weights on it in a line! It must have not got the memo about factory cast wheels!!
Old Mar 29, 2018 | 03:57 PM
2500hdon37s
I guess if you havent ran beads you wouldnt understand. And with such a light tire like a skinny motorcycle front its not too surprising you can get away with no weight.
I've been running beads in tires for 10+ years now and its amazing how well they work. I've went over 100mph with 37x13.5in mud tires that were bead balanced and they were as smooth as it gets. Beads work, simple as that.
Old Mar 29, 2018 | 04:37 PM
Cobra1's Avatar
Cobra1
Why so many people think beads rolling around in there is doing something..
Mainly because they work. Smoothest my bikes have ever been since I started using them over 5 years ago.
Old Mar 29, 2018 | 05:31 PM
1957buick's Avatar
1957buick
ride - on balancer and sealant
Old Mar 31, 2018 | 07:35 AM
grbrown's Avatar
grbrown
It's not unusual for tyres to need no balancing weights these days, as manufacturing techniques get more precise. Ride and see what your bike behaves like. You trusted the shop to replace your tyres, trust them to say if they are balanced!
Old Apr 6, 2018 | 10:23 PM
.:eMETAL:.'s Avatar
.:eMETAL:.
https://youtu.be/eq263AYgyYg
running beads in my wheels now on the RK. About to put them in my 35s on the Jeep. Glad to know you’ve had them in 37s with luck. I like them on the bike so far, easy peasy.
Old Aug 1, 2018 | 09:14 PM
mmowrey's Avatar
mmowrey
3rd Gear
Can beads be used in tubes tires?
