Tire Size
Old Feb 20, 2019 | 12:38 PM
txjjholt's Avatar
txjjholt
Stage II
Default Tire Size
I'm trying to find out if a 200/55/18 will properly fit on my 2011 CVO StreetGlide which currently has a 180/55/18,just trying to get a little more traction ?
Old Mar 21, 2019 | 12:07 AM
Bluesman8028's Avatar
Bluesman8028
Whether it will fit inside the fender or not I'm not sure, but the difference in width is pretty significant. The stock 180 tire is 7.1" wide and the 200 tire is 7.9" wide. It will also lower your speedo reading by 2.1 mph @ 60 mph.
If you still want to go with the wider tire, you should probably go with a 200/50r18. It's much closer to the same circumference and only a .2 mph difference in speedo reading.
Old Mar 27, 2019 | 05:29 AM
Hopey's Avatar
Hopey
Stage IV
Hi
My first Harley at 55, which I did it years ago.
got s 2018 FXFBS white Fat Bob
Done a few modification but am looking at playing with the suspension rise the back lower the forks in the tripple clamps just to get a bit more ground clearance but my question I'm seeking an answer to is
Has anyone changed the front tyre from a 150/80/16 to a 130/90/16?
in theory this should make the steering quicker and lighter.
Anyway has anyone done this and should I do it or just learn to ride what I have?
Thanks
Hopey
dharmon23
Wheels/Tires
Jun 25, 2015 02:26 PM
hellbob37
May 19, 2012 10:44 AM
blockzilla
Sep 7, 2011 04:12 PM
sonar_chris
Nov 28, 2009 09:49 PM
rogerfromco
Jun 28, 2009 09:37 PM
