Clarification wheel 43402-00B
Old Mar 26, 2021 | 01:47 PM
eighteight's Avatar
eighteight
Default Clarification wheel 43402-00B
I call these "wagon wheels" and they were fitted from `00 to `08 without a part number change ( the bearing & sleeve p/n`s do change)
Bought 3 this AM , all have 3/4" i.d. sealed bearings.
I "ASSUMED" sealed bearings AND 1" axles started in `00, ??
OK, perhaps someone fitted 3/4" bearings for their application
The supplied sleeve for 3/4 axle is 1" O.D. and the bore in the wheel is only minimally larger
My third assumption was that this wheel could be fitted with 1" or 25mm bearings but obviously the larger sleeve will not fit in the existing hole
Will investigate more closely when I get them home
Multihdrdr, and others, what am I missing ?
Thank you
Old Mar 26, 2021 | 04:35 PM
multihdrdr's Avatar
multihdrdr
They are probably ALL Rear Wheels?
2000-01 Touring used 3/4" Sealed bearings in the Rear along with the 1" in the front
The Rear Wheel available through "Parts" is the 1" wheel because you can use it for both applications
Old Mar 27, 2021 | 05:31 AM
eighteight's Avatar
eighteight
Thank you sir, ^
One is a front wheel, it also has 3/4 bearings.
I haven't removed them to check the bore but it appears the sleeve has more "slop"
Evidently someone`s "work-around"
Thanks again
Old Mar 27, 2021 | 07:21 AM
multihdrdr's Avatar
multihdrdr
Yeah, you should find that that "front" will have the larger clearance hole for the 1" parts.
Old Apr 5, 2021 | 05:26 AM
eighteight's Avatar
eighteight
^ Thanks for the info. Helpful and accurate as ALWAYS !
Got the rears cleaned up
Old Jul 12, 2022 | 06:14 AM
CherryPL's Avatar
CherryPL
Stage I
Default Show pictures
Hello Mate,
Would you be so kind and show us how they looks on your bike ?I am thinking of fitting them to my sportster as well.
Curious how they look.
Thanks,
Peter
Old Jul 12, 2022 | 06:42 AM
timbo141's Avatar
timbo141
M
Excellent work, those wheels look new!
Erix-2008
Feb 7, 2018 09:26 AM
Ozark Joe
EVO
Jan 4, 2017 12:39 PM
rolfsharley
Mar 8, 2014 05:09 PM
FatboysFatboy
Wheels/Tires
Nov 27, 2012 09:30 PM
Razorback Rob
Mar 29, 2012 05:49 AM
