Changing From Spoke to Mag
Old Jul 28, 2022 | 06:17 PM
thedevilinleather's Avatar
thedevilinleather
Default Changing From Spoke to Mag
My tire size is the same, the axel spacer is correct for the bearings currently installed. My question is the spacers on the axel between the swingarm. Where do I start what should I be checking and looking for? I do know I did have to add a spacer for the sprocket because on the new rim the belt would rub the tire. I have stayed with the original size tire. I want to ensure I still have the proper spacing i need in the swingarm. 1998 FXDWG that was spoked to a custom rim.
Old Aug 5, 2022 | 06:24 AM
Phil13's Avatar
Phil13
Wheel central, allowing for offset hub, belt / chain run, disc / caliper alignment. Once you have the alignment for those, you will then be able to determine your axle spacer dimensions. I use a stack of large washers to get me where I want to be, tightening the axle up, making sure everything stays where it should be. Then measure the stack. Allow a 1/16 "nip up" space to enable the swing arm to clamp the Wheel / axle.
JoeD-8541
Jun 17, 2020 09:53 PM
Kenny B
Wheels/Tires
Aug 18, 2014 07:31 AM
blackyck
Sep 15, 2010 09:27 PM
godjunior
Jan 3, 2010 05:43 PM
cajun883custom
Jan 21, 2007 05:36 PM
