Wheel direction?
Old Dec 18, 2022 | 10:18 AM
h-d wrencher's Avatar
h-d wrencher
Originally Posted by Y2K
That's what I was thinking as well as why just a front,with my luck and prior experience I'd get a rear flat,seems to be the rear far more often being the driven wheel.
I already have a rear spare mounted.
Old Dec 18, 2022 | 10:59 AM
touchdown's Avatar
touchdown
Originally Posted by h-d wrencher
We go to Daytona in March. If I have a tire issue and need to be towed, I can swap out a tire and wheel myself. Why be towed to a service place and pay for a new tire to be installed when i alredy have one?
I think what you need is a van with a extra parts bike. Hell, I thought you were going on a long ride not just to Daytona.
Old Dec 18, 2022 | 11:12 AM
h-d wrencher
Do you carry a spare parts vehicle in your daily driver or just a spare tire in the trunk?
Old Dec 18, 2022 | 11:19 AM
Uncle Larry's Avatar
Uncle Larry
I think the curiosity exhibited here is expected ... If you do have a flat tire are we supposed to assume that you carry both the front and the rear tire with you on the scooter? Maybe just the front and hope that does the trick, or perhaps the rear the in case you have a blowout in the Burnout Pits at the Iron Horse ? Ride safe and keep an eye on those tires :>)
Old Dec 18, 2022 | 11:32 AM
h-d wrencher
As stated earlier, I can have the bike towed back to wherever I am staying and swap tires and wheels myself. I do not plan to carry the spares with me on the motorcycle. That would be crazy. Where would I put the motorcycle jack? Ha Ha!
Old Dec 18, 2022 | 12:10 PM
h-d wrencher
Originally Posted by CoolBreeze3646
Check the color of the bearings, if it was an ABS wheel they will be different colors, then you will know which side it goes on.
One bearing is black. Other is white. I assume the white goes on the left clutch side?
Old Dec 18, 2022 | 01:02 PM
rocketnorton's Avatar
rocketnorton
front kicks up chit for rear to eat
Old Dec 18, 2022 | 02:27 PM
Y2K's Avatar
Y2K
Okay well now it's more clear,I'd assume now that you are trailering the bike to the rally not riding it.
Old Dec 18, 2022 | 05:40 PM
smitty901's Avatar
smitty901
Rotors are marked right and left.
Old Dec 18, 2022 | 05:42 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Here is how you determine which side of the wheel is the left side:
Remove the wheel bearings (toss them into the scrap can), look inside the hub, there will be a lip on the left side of the hub that the bearing is pressed against when installing.
