Wheel direction?
Old Dec 17, 2022 | 11:37 PM
h-d wrencher's Avatar
h-d wrencher
Default Wheel direction?
I just picked up a spare stock wheel to mount an old tire on to take along on trips. I don't see any directional arrows on the wheel and it wasn't marked when it was removed with about 35 miles on it. I know the tires are directional but are the wheels directional? No markings on the rotors either. Thanks in advance.
Old Dec 18, 2022 | 12:03 AM
Jackie Paper's Avatar
Jackie Paper
Any difference between the offset from the rotor face to the rim face?
Old Dec 18, 2022 | 12:05 AM
TriGeezer's Avatar
TriGeezer
Why put an old tire on a new wheel?
Old Dec 18, 2022 | 12:29 AM
h-d wrencher
No difference on offset. I shouldn't say old tire. There was about 1k miles on it when removed.
Old Dec 18, 2022 | 06:04 AM
RANGER73's Avatar
RANGER73
As the picture is of a dual disk rim not a "tire" the rim isn't directional.
If the valve favors 1 side and not centered, it should be mounted so it's on the throttle side.
Old Dec 18, 2022 | 06:52 AM
CoolBreeze3646's Avatar
CoolBreeze3646
Check the color of the bearings, if it was an ABS wheel they will be different colors, then you will know which side it goes on.
Old Dec 18, 2022 | 06:57 AM
MURPHCC1's Avatar
MURPHCC1
The valve stem is usually NOT centered on the wheel............. I thinks its on the RIGHT side, it is on my 07.
That would tell me the direction of rotation
Old Dec 18, 2022 | 09:07 AM
touchdown's Avatar
touchdown
What kind of trip are you going on that you need a spare tire and wheel?
Old Dec 18, 2022 | 09:55 AM
Y2K's Avatar
Y2K
That's what I was thinking as well as why just a front,with my luck and prior experience I'd get a rear flat,seems to be the rear far more often being the driven wheel.
Old Dec 18, 2022 | 10:16 AM
h-d wrencher
We go to Daytona in March. If I have a tire issue and need to be towed, I can swap out a tire and wheel myself. Why be towed to a service place and pay for a new tire to be installed when i alredy have one?
