Recently a friend had a valve stem fail while on the highway. How often do you guys replace them? He had an aftermarket angled type. Could that have been the factor? Kinda scary 😧
Angled stem face much more centrifugal force than vertical stems do. Don't go cheap here.
(I recall the 'dice' valve caps that were sold awhile back wrecking the rubber stems they were attached to. Rubber stems can't handle that.)
The internal TPMS system that I installed (Sykik) only offered straight stems.
I would have expected the angled stems to be a better option, certainly for ease of use.
I am curious about which component has failed; O-ring, plunger, etc.
