Fender clearance front and rear 2003 Softtail Heritage
Old Apr 12, 2024 | 08:54 PM
GrassLobster's Avatar
GrassLobster
Default Fender clearance front and rear 2003 Softtail Heritage
Hello all,
Always have wanted a Softtail bobber and it looks like this is the year. Starting out with 150/80b16 tires front and rear. Anybody have a scientific value on how much space is needed between front fender and tire sitting cold? Then, same question in the rear with some tire growth at speed along with who knows how much suspension bounce as it will be mounted to the same frame rails the typical fender is attached to.
Any guidance is much appreciated.
Old Apr 13, 2024 | 05:39 AM
user 7209823083's Avatar
user 7209823083
Originally Posted by GrassLobster
Hello all,
A radial tire grows maybe 1/8" in radius at high speed, and nothing in width. So for your front fender you can go very close.
For the rear you need to take into account the suspension bottoming out, if you are running with a passenger or heavy luggage.
Old Apr 13, 2024 | 06:14 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Welcome Brad as a relatively new member. Post a picture of that completed project for sure someday.
Only as a suggestion, make your next new post over in the new member welcome area to say hello.
https://www.hdforums.com/forum/welcome-area-only-4/
Old Apr 13, 2024 | 08:51 AM
GrassLobster
Thanks for the info on the front. Any idea how much give is in the rear suspension at full crunch? I am afraid of cranking in the fender frame mount to pull it down and don't really want to guess.
Old Apr 13, 2024 | 09:06 AM
Jackie Paper
My 04 has SE rear shorter spring/shocks. About a 1" loss of travel in suspension.
I set shocks at the minimum pre-load. Doesn't take much to hit the bump stop with my 190 lbs.
Not going to hurt it pulling it down with straps.
You need to know what you have if you start filling that wheelwell up. There is bolts sticking in it and a rear taillight harness.
Old Apr 13, 2024 | 09:18 AM
GrassLobster
Got it!
I will rachetstrap the back end down to see where it stops. I am removing a good portion of the rear fender, but the bolts that mount it will still stick out on the inside. Thanks for reminding me ot that!
Old Apr 13, 2024 | 09:23 AM
Jackie Paper
Be sure to post what it is. Another thread on here says 4"
Aces N Eights
Jul 29, 2021 08:14 PM
2010Deluxeguy
Jan 29, 2012 09:44 PM
BK Meyers
Nov 21, 2008 08:00 AM
95Heritage
Jun 6, 2008 09:57 AM
sickshovel
General Topics/Tech Tips
Jun 19, 2006 12:40 PM
