Hub damaged while removing race
Old Feb 10, 2025 | 10:35 PM
squidman88's Avatar
squidman88
Stage IV
Default Hub damaged while removing race
So I was rebuilding the hubs on the front and rear wheel of a 1976 FXE and I installed a bearing race in the rear wheel backwards... After breaking many tools I finally got the fu**er out with a dremel but I damaged the inside of the hub pretty bad in the process. Does anyone think this damage is bad enough to be structural? I want to just throw another race in there and run the wheel but I'm looking for a second opinion. Thanks.
Old Feb 11, 2025 | 03:46 AM
eighteight's Avatar
eighteight
Dress down the high spots and run it.
Old Feb 11, 2025 | 05:28 AM
MURPHCC1's Avatar
MURPHCC1
I agree.
Old Feb 11, 2025 | 06:13 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Welcome to the HDFORUM. Hope you stick around to enjoy the ride here too.
Old Feb 11, 2025 | 07:18 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by MURPHCC1
I agree.
Old Feb 11, 2025 | 08:38 AM
jake24lt's Avatar
jake24lt
Next time run a bead of weld around the cup, "race" . Let cool and it will fall out!
Old Feb 11, 2025 | 08:49 AM
bustert's Avatar
bustert
hummmmmm?????
steel cup and aluminum hub with diff expansion rates. do not see this happening and lordy do not hit the hub with the arc.
it would be better to use the dremel to cut a groove at the upper rim and the use a expanding puller. but if the new race fits tight then go for it. seen WAY worst carnage.
Old Feb 11, 2025 | 09:28 AM
Harley_ish's Avatar
Harley_ish
Or use a proper tapered roller bearing outer race remover next time
Old Feb 11, 2025 | 10:37 AM
squidman88's Avatar
squidman88
Stage IV
Thanks, that's all I needed to hear!
Old Feb 11, 2025 | 10:43 AM
squidman88's Avatar
squidman88
Stage IV
@Harley_ish That's what I used to get the 4 old races out, with a little heat it worked great. Wouldn't work when the race was installed backward no matter how much heat I used
