softail deuce front wheel
Old Apr 3, 2026 | 02:31 PM
nascar7613's Avatar
nascar7613
Default softail deuce front wheel
I want to replace the front wheel on a 2007 deuce. The wheel on the bike is the original 21x2.15. Is there a difference between the deuce wheel and other softail wheels that are the same year, such as hub width. I can't find the hub width of the stock wheel anywhere that I have looked. From what I have found, the stock wheel has 25mm bearings. I have found aftermarket wheels the same size with 25mm bearings, but they list them as 08 and later with abs bearing, maybe the bearing is why they are listed as 08 or later.
Old Apr 4, 2026 | 09:20 AM
multihdrdr's Avatar
multihdrdr
2007 Softails were the first year for 25mm bearings and in the front wheel only so the 2008 wheel would be the same. (Springers would be an exception)
FWIW Softails didn't start using ABS until 2011
Justin Georges
Wheels/Tires
Feb 10, 2022 04:41 PM
MJobe
Aug 13, 2021 09:35 PM
thephantomsfire
Jun 13, 2012 01:40 PM
HDinPHX
Jun 2, 2011 04:51 PM
rounder
Jul 7, 2008 09:47 PM
