Setting Up Wheel Without Bearings
Old May 6, 2026 | 09:01 PM
HellaGNARLY's Avatar
HellaGNARLY
Default Setting Up Wheel Without Bearings
Trying to run a front Invader I just got. Will need larger bearings for the 3/4 axle but doesn’t have any internal spacers or anything.
Are there bearing kits out there that includes spacers for inside the spool? Or am I going to have to make the spacers based on the spool width? Talking about the spacer in the spool and not wheel spacers. Last chop I used a new Low Brow wheel that was already set up so this is new territory.
Old May 7, 2026 | 04:32 AM
eighteight's Avatar
eighteight
I assume the distance between bearing race "seats" to be less on the Invader than the OE hub ?
I`d buy the H-D spacer and cut to fit
( 3/4" black iron pipe is .820 ID and 1.050 OD So that`s a "maybe" , you need to measure )
Old May 7, 2026 | 10:58 AM
HellaGNARLY
Correct. The mini spool width is 3 1/4" I believe. So if I subtract the width of both bearings/races & the end play, that would be the length of the spacer. I've never had to do this before so I wonder if there are spacer kits or if it would be a custom job.
Old May 7, 2026 | 03:34 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
What model, year bike are you working on?
What type bearings?
Old May 7, 2026 | 03:54 PM
HellaGNARLY
What type bearings?
It's all custom - chopped a '71 FX. Nothing is stock on the front end other than the 35mm lowers. Ultra narrow trees, +8 35mm forks, ultra narrow 3/4 axle and an old 17" Invader mini spool wheel. It currently has (1) 3/4" sealed bearing installed but there's no internal spacer.
Old May 7, 2026 | 03:59 PM
Dan89FLSTC's Avatar
Dan89FLSTC
You need to know the required space between the bearings, keep in mind that one bearing probably is pressed all the way against a shoulder in the hub, but the second bearing you install will not be pressed against a shoulder.
Sorry the illustration is so big...
Old May 7, 2026 | 05:04 PM
HellaGNARLY
Here's what I came up with.
I believe the HD tolerance for endplay is 0.014, so if I split that and subtract the other widths - I come up with a 2.236" spacer?
3.25 Spool
-0.5Bearing
-0.5 Bearing
-0.007 Endplay
-0.007 Endplay
_____________
2.236" spacer
Old May 7, 2026 | 06:44 PM
Harley_ish's Avatar
Harley_ish
"End Play" ? ... so you are using Tapered Roller bearings? (NOT ball bearing)
Old May 7, 2026 | 06:57 PM
HellaGNARLY
Is endplay only for tapered bearings and not sealed? I’m new to this.
Old May 7, 2026 | 07:40 PM
Harley_ish's Avatar
Harley_ish
"Setting" (& checking) end play is for Tapered Roller.
You can check end play on Sealed Ball, but that's just for checking internal bearing wear.
So what are you using?
